So the build i have for my nytro is a 240hp ulmer kit and am running 10-11psi at about 2200ft. Now when i went to the mountains over the new year i was at west yellowstone sooo roughly 7200ft-9000ft i was only creating 7psi. Now because of the less denser air up in the mountains would i just only have to turn up my boost controller to compensate for thr less dense air so i would be back up to 11psi? Any info helps thx.
Sent from my LG-H831 using Tapatalk
Yess turbo is big enough to be used at 11psi at 2200 ft so should all be the same then regardless of elevationYes, as long as your turbo is capable of it.
