Looking to supercharge a 2012 Nytro xtx to run at sealevel (5lbs of boost), is it necessary to run extrovert drivers or will the stock drivers work? Also is it possible to use a 6000ft supercharger kit and tune it to run at sealevel?
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
The Stock ones will do just fine at 180 HP.
Yes it will work, I have done an installation of a 6000ft kit on a sea Level sled.
You need to og down one tooth on the crank sprocket to run 27/28 engine/charger gearing.
If I remember the 6000ft kit comes With 28/28 gearing.
You will have to change the settings on the GEMS Box in order to have enough fuel to run at sealevel.
