brendan.9
ttt
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
What awnsers are you wanting brenden.9? I think its been covered.
Less tehn 5 psi will run on pump premium
No premium available it will blow up, you need torco race fuel concentrate to make up the octane. It has to be that not some gas station crap that makes no difference.
Want more power? Shim the head for 10:1 compression and swap the pullies on the kit for 10-11 psi and it will run on pump premium, same rules apply for lower octane as above.
The kit fits like OEM, can be very reliable.
The downsides? If you dont have premium it will be frustrating to always add and carry torco
Cant say on a nytro but on my apex mpg is a real issue I only get 50-60 good miles before I'm worried about fuel then it will last till arond 80-90 miles on a tank but the last few aren't fun if Im trying to save it and get to a gas stop. I'm adding more fuel capacity to mine this summer.
the stock fuel sys is maxed out at 5 psi on a nytro, a friend tried running his at 7-8 psi with fuel pumpupgrade andstock injectors it would lean out beyond safe, upgrade to mpi blowoff valve,also a good afr guage, vacume/boost guage,and coolant tempguage
brendan.9
okay so if i have to run regular i should lower my boost i wear a backpack so can carry a few bottles. if i do this the plan is mpi stage 1, back country 1 3/4, clutch kit, full exhaust, possibly meth kit, new set of skis don't know what kind???? trail tank. what else do you think i need and a aprrox cost? thanx brendan.
add the cool air intake from mpi, by the time you add in guages,blower,tank,skis and track/drivers, the cost will be up in the 6k+range
brendan.9
i also wanna be able to run 11psi on premium
definately lower compression ratio, and upgrade entire fuel sys
SledFreak
- Feb 7, 2005
- Ontario. Canada
gsxr said:I run a 2010 xtx , supercharged , extraverts , cold air kit , clutched with Ulmers kit , Apex gear , studded 2 per bar , upgraded fuel kit , afr gauge , boost gauge, 5161 km this winter @5-6 lbs boost. Lkae running , trail mix , ran any fuel I could get, Premium when avaliable.
Runs fast , fun , Trade , sled for sled if yous is stock $4000 diff, Iwill trade it it for the 2011 eps apex.
But, did'nt it blow up?
greenmtnboys
Do you guys change altitude much at all or are you running on the flat
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
kinger said:What awnsers are you wanting brenden.9? I think its been covered.
I would say shim the head 9-1 instead of 10-1.
work great and fully reliable on premium at 10 psi.
brendan.9
it don't change pretty flat out here unless we decide to go to the mountains.greenmtnboys said:Do you guys change altitude much at all or are you running on the flat
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Lower compressoin to at least 10:1 and add water/meth injection and fuel would not be a problem, also keep the boost low.
I'm at 20 lbs running premium fuel, 10:1 CR and meth injection.
- 13K
