basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
Went riding yesterday long story short first ride of the season brand new oilite bushings and i hit RR ties stacked up under the snow 10 mph to 0 instantly. My bottom a rms and bottom of the spindle could move back and forth alot. Not good. The mounts on the frame look fine. Bolts where bent. There is alot of room where the bolt goes through the bushing isnt it suppose to be a tight fit?? I need alot of help here fellas. Btw both sides ended up getting messed up.
nytroman20
Looks like you're missing a sleeve. There should be an aluminum sleeve that fits between your bushings. Same inside diameter of the bolt.
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
SOAB...!!!!!!!!! Them never got installed when i put everything together I bet.
nytroman20
On the positive side.... Everything looks straight. Just get those sleeves in and you'll be good to go.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
How does your subframe look?
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
That sucks basic, hope you didnt bend anything. It also looks like your bushings are cracked or is that just the picture? Hope you can find those sleeves in the left over parts pile
sledneck22
You should have seen the disappointed look on his face when he hit those railroad ties! I am willing to bet a new set of bolts, put the sleeves in, and tighten it back up and everything will be fine.
Might have to adjust the toe in/out but will be ship-shape and good to ride.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
sledneck22 said:You should have seen the disappointed look on his face when he hit those railroad ties! I am willing to bet a new set of bolts, put the sleeves in, and tighten it back up and everything will be fine.
Oh I can just imagine, I think I had the same feeling when I skimmed that pole with my ski and bent my sub frame on my last ride last year. Pretty disheartening, parked it and didn't even want to look at it I was so pissed off. This doesn't sound that bad at all, hopefully hes up and running soon.
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
I found all 4 of them sleeves going to try and press them in tonight orderd 4 new bolts b/c the old ones where kinda bent. I bent the carbide on my sly dog skis. 2nd one! Fricken sick of it im going to try and get a set of pilots.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
basic700 said:I found all 4 of them sleeves going to try and press them in tonight orderd 4 new bolts b/c the old ones where kinda bent. I bent the carbide on my sly dog skis. 2nd one! Fricken sick of it im going to try and get a set of pilots.
Shouldn't need to press them in, just clean up the sleeves a bit and they should slide in without a press.
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
They are going to need a little encouragment
nytroman20
Put some grease on them before you put them in. One less worry
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
if they need encouragemant then ur arms/bushings may have an issue. I would not press them in because the bushins rotate on the sleeve.
GHLYAMMY
I had to use sand cloth to reduce those sleeves so they fit in the new ulmer bushings....the sleeves are a fairly big portion of the install..
