Charged RTX
Has anyone tried to replace the bottom gear and found that it was not the same as the factory one? I got a 39 tooth from Hauck (no reverse) and it had a wider hub and came with a thin washer. I tried to install it one day in a hurry and could not seam to find a combination that would align properly. Hauck says to remove the big factory spacer and install the gear and the thin washer.
170plus
- Jan 14, 2004
- washburn maine
- 2021 polaris assault 850,18 sidewinder ltx,14 nitro xtx,06 apex rtx,
i put a team industries bottom sprocket on my 03 rx1,same deal,remove big psacer and install sprocket with thin washer behind it
Charged RTX
Maybe that will be fine. I was in a hurry when I was trying to figure it out. I was trying to get it done beside a lake to race some cats. I think I remember 1 combo that was close but the gear stuck out past the axle more than the stock one. Is this normal?
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
No not normal,u you need to align them up even,if not your chain will get hagged out, i run poo gears,same thing,need to shim differently to get them to work,take your time and use a straight edge to make sure they are square to each other,also make sure that the gear you have that is not a yammi is a hyvo cut,not a 13 or 3/4 old style cut,they look alot alike,but dont fit up togeather,the hyvo chain will not sit down into the gears..Charged RTX said:Maybe that will be fine. I was in a hurry when I was trying to figure it out. I was trying to get it done beside a lake to race some cats. I think I remember 1 combo that was close but the gear stuck out past the axle more than the stock one. Is this normal?
