venom
thought that i had clicked on all the threads of yours hammer but i guess not.thanks again.........
thanks ted you guys are very helpful.i only want to buy things once and have work with no issues.think i made a mistake buying the stage 1 kit i want more power and it was only my first ride but i got a pretty good deal on it.think i'll upgrade to the stage 2 next year.
If you click on the search function and use Search for Keywords: supercharger and Search for Author: hammer you will find 18-threads of reading material.....bolted my super on last year.....learned and posted a bunch since then....for a wider search just fill in the Search for Author: hammer portion and you'll get 204-threads of reading material.
A
Anonymous
Ted Jannetty said:mulot30th said:Ted Jannetty said:The Turbo XS BOV is a poorly designed BOV, they don't open when you need them to and they leak boost.
I Use a Vortech race bypass, yes it cost a lot more but you get what you pay for.
Very light spring pressure and large diaphram alows it to open very easy even at idle and light throttle but never leak boost all the way to 30 PSI and beyond.
It Features and ORing seat, adjustable spring pressure, large diaphram, 1.5" opening, that is rated for up to 400 hp.
Don't settle for less.
Where do I get that kind of BOV?
And have a picture?
http://www.vortechsuperchargers.com/Mer ... ry_Code=AC
Polished
Satin
Pricing may not be correct, I find a lot of old info on that site.
#*$&@ men.. that thing weight 3 pounds
They must use a really big box with a bunch of advertising crap in it.....LOLShipping Weight: 3LBS
FASTSLED
VORTECH BOV
TED ,SELLS THEM VALVES I BELEAVE
A
Anonymous
How much this thing really weight?
I am not gonna install a 3 pound piece of iron on the nose of my sled...
FASTSLED
VORTECH
I RUN ONE ON MY OUTLAW SLED NICE VALVE NOT 3 LBS IF NOT LOOK AT TIAL I THINK THE BEST YOU CAN BUY MORE $$$ THAN THE VORTECH ??????
Travis Moore
Go for a HKS...they are a pull design (not push like Ted described). More boost only holds then shut harder
T
T
Ted Jannetty
- Nov 24, 2003
- Waterbury Ct.
- www.jannettyracing.com
Travis Moore said:Go for a HKS...they are a pull design (not push like Ted described). More boost only holds then shut harder
T
Travis Travis Travis, your always bucking good info, Get your facts straight, Vortech is a pull design.
Vacuum open, Boost shut.
Merry Christmas.
Travis Moore
Ted Jannetty said:Travis Moore said:Go for a HKS...they are a pull design (not push like Ted described). More boost only holds then shut harder
T
Merry Christmas.
Ted Ted Ted....you described a push type (Turbo XS). You did not describe your Vortech-just said it worked better.
Happy New Year.
T
