The failsafe in the meth system is a flow control measuring the amount of fluid passing the controller. If the flow drops below a set threshold the controller will trigger a 5 Volt signal that can be used to control or trigger whatever system that can take a 5 Volt analog signal. In my system the 5V signal opens a solenoid that bypasses my manual boost controller so the wastegate drops boost to the preset WG boost of 12 lbs, boost controller is set to adjust boost from 16 lbs to 22 lbs. At 12 lbs I'm safe on pump gas without the meth.
I would have to guess, but you should be able to use the 5 V signal from the Meth fail safe controller and use it to open the BOV to drop boost.
