vipermike2002
- Jan 19, 2006
- Barrington, IL / Rhinelander, WI
- 07 Attak
While I was out riding last weekend the left front shock broke. I need to get this replaced, what are my options? Where can I buy the replacement parts? Any recomendations for afterparket shocks?
THANKS
THANKS
Red2003
Replace BOTH front springs with after market strait rate springs. Pioneer Performance and Maxximum Performance both sell them. I'd go with the 2.3's if you ride aggressively. 2.1's if you are a slow poke. They are about $100.00 shipped from either place. No need to replace shocks. Jack up front of sled unhook shock, unscrew adjuster nuts and drop the spring off. When you replace the springs, DO NOT preload them. Tighten the nuts just enough to make contact with the spring with the front end jacked up. You'll love the difference in handling over the stockers. Get R Done! Or, I have a set of stockers that are mint. I'll make you a whale of a deal. PM me.
race24x
- Dec 29, 2003
- Belgrade, Maine
- www.r-scomputer.com
If you liked the stock springs I have mine I replaced with the ones mentioned about I could send them to you 25 plus shipping I wont use them as I am 260 without gear but the ones above do help for tipping in corners too.
ecarnell
Update your profile to where your located.
I have a set of used stock ones that you can have if your in my area and are able to arrange a pick-up.
or spend the $89US for the well worth upgrade. http://www.pioneerperformance.net/
vipermike2002
- Jan 19, 2006
- 07 Attak
Sorry, but it wasnt my spring that broke it is the whole shock.
THREAD HAS BEEN EDITED
THANKS
THANKS
JDKRXW
Call Pioneer Performance for new shocks ....and replace both stock springs with straight rates. This is a very nice handling upgrade for not much $$$
I agree with JDKRXW, I have had great luck with them on both of my RX1's and my other Yami's
By the way, if you would still need springs, I have a set off my 05 that have about 450 mi on them. I took them out when I installed my Pioneer wide kit.
vipermike2002, While I was surfing the site I noticed that Apexaholic has a new set of Fox floats for sale. PM him if you are interested.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Those won't work on an RX-1.RedRX1 said:vipermike2002, While I was surfing the site I noticed that Apexaholic has a new set of Fox floats for sale. PM him if you are interested.
