hoov165x
- Aug 21, 2006
Vmax4 said:I posted this once before......... When I called yamaha they told me there was no problem, and there was no update kit.
Look at the pics on this thread................... and then find a good dealer to go to bat for you!
rfabro
Do you have, or can you get part numbers, hoov?
hoov165x
- Aug 21, 2006
rfabro said:Do you have, or can you get part numbers, hoov?
I don't have the part numbers, but I will call the dealer this pm and see if they have a #.
Hoov
keithstef
We also broke the front arm, linkage and bent the center shock.hoov165x said:rfabro said:Do you have, or can you get part numbers, hoov?
Hoov
Please post info so we can info our dealer..
Keith
I have broken my linkage too. Currently on backorder in europe.
hoov165x
- Aug 21, 2006
OK, here is the scoop. For those of you that have broken your rear suspension linkage, you need to have your dealer call the Midwest Yamaha RTA(regional tech adviser) in Pleasant Prairie, Wisconsin. Your dealer will have this number. My dealer said that there are were no part numbers attached with the new parts- they just came bubble wrapped in a box.
Hoov
Hoov
rfabro
Thanks for the info, hoov.
Recieved my new linkage today. Unfortunatly its not any diffrent from the one that broke in the first place.
I think i will have to reinforce this part or make a new billet one. Its obvious that it will break again otherwise.
3 out of 4 Phazers that i ride with has this problem.
Update: My dealer has confirmed that there is a reinforced kit available, recieving it this week.
Will take some pics if i get a chance.
rob
Just had mine fixed. arm broke shaft seized and one bolt backed out. then other side wobbled out and tore up the rail. yamaha fixed everything. I was thinking about going back to polaris but if yamaha will stand by there product than I will have no problem buying a new next year. Because I really like the 4 stroke motor.But I think I'll be selling the phazer and buying the rtx nytro and hope it will hold up a little better. I race motocross (quads) So I might be a little rough for the Phazer.But its a fun sled.
- 10K
