MyOutdoors
- May 4, 2003
- Lempster, NH
- 2020 Sidewinder Ltx Se
The bolt idea makes sense also, but I think it would interfer with the center rod?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Wolf...Ill give ya a call...Dano needs one!
thanks
Dan
thanks
Dan
RTXs
If mine blows out again im gonna remove it and forget about it. I dont think my track can handle any more damage from the rod, its pretty tore up.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
RTXs said:If mine blows out again im gonna remove it and forget about it. I dont think my track can handle any more damage from the rod, its pretty tore up.
I totally agree....if these things cost 300 bucks,id be removing it altogether and tightening the strap as much as is needed to control too much wheelie...this is how all the OLD sleds were prior to control rods.
then that annoying ROD noise in studder bumps will be gone too!..LOL
Dan
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Did the 05 mono have the same control rod? Have many of those broke?
Just blew mine out on my SRX (05' MONO SKID) today so i removed the whole dam rod and i did not feel anything rubbing or hitting. Got it home and got a closer look and it appears you could ride without the rod in and not do any further damage to the skid (IMO) but now i have to ride the throttle. Can you ride without the rod and not do any damage?
Tork
Yep broke mine too, well the threaded coupler pulled out of the cylinder.
Tested without it, not too bad really. If you have good hook-up you will pull the skis by what feels like about 8 inches. Other than full throttle, you might not know that it is missing
MyOutdoors
- May 4, 2003
- Lempster, NH
Did you just break yours recently Tork?
MyOutdoors
- May 4, 2003
- Lempster, NH
Well dealer called and they(Yamaha) will warranty it "under good faith". Rep stil told dealer that rod will not come undone or strip if it is adjusted properly. Any who, I'll have a brand new transfer rod for sale for $200 plus shipping to anyone who needs 1. I had purchased it from another dealer friend @ cost, waiting for warranty answer. Anyone need it?
Oak Hill
- Dec 19, 2004
- Owosso, Mi
- www.airtoolexpress.com
The one in the picture looks like it came loose, not any pulled threads.
MyOutdoors
- May 4, 2003
- Lempster, NH
Oak, your right. The threads are messed up but I believe it was from the damage after it came apart.
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
How about having a bunch of us try putting Blue Loc-Tite on th ethresded part of the adjuster? Set it the way you like it, turn it out while counting the turns, Loc-Tite it, and screw it back together, then Loc-Tite the jamb nut? I thought about the plastic screw thing as well, and that would be a great possibility as well. I would take my transfer rod out, have someone machine a flat spot (or 2) in the threads so you can contact it on a flat surface.
If the issue is coming from the adjuster nut backing off, how about fashioning some sort of clamp on the aluminum body, and safety wiring the jamb nut, and or the adjuster? As long as it's set right, You shouldn't have to mess with it.
~Nate
~Nate
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I finally looked at mine closer,and its adjusted to HALF....I thought it was closer to max all these months...
Danos broke last week,which his was closer to MAX....If you have one for sale can you please PM me about it?..dano might be interested in it.
I HIGHLY recommend keeping it CLOSE to medium setting...If you ride this sled real hard,you MAY breakout threads if set to MAX on wrench.
I have my strap to tightest,only 96 studs and medium transfer on rod..and it still hooks on holeshot..In my case I have no need for max transfer.
On a side note...Dano Loves his new wheelie machine!...LOL...but,it does stay under control If you want it too..
Id say,you very way could ride without the rod altogether without probs....Dano has been!
Dan
Dan
MyOutdoors
- May 4, 2003
- Lempster, NH
I'll PM you
MASTERBLASTER
banging
To reduce the banging noise I removed the nylon washer and installed a rubber one in its place.. I also keep the transfer rod in the middle.
But the sled was lifting the nose too much and the skis would dance coming out of a corner.. This was a workout and very unstable.
I then tightened the limiter strap two holes and the sled handles very flat and hooks up good.
I have a 2006 Attak..
