whitewheels
Got answer from van amberg and their cooler would be enough to replace the front radiator.
Also had to return my red artic secondary clutch spring(it was just lend to me). It was an old one without any marking so after some searching from my local artic dealer it turns out it was red white
whitewheels
Time to wake this baby up from summerhybernation
To do list:
Got a used k&n filterkit
Litium battery,relocated under the seat
Hopefully a couple of billet tunnelwheels
Roll over valve
....and I´m going to make a new seatframe that is a couple of inch lower at the back
Some more powdercoating
To do list:
Roll over valve
whitewheels
Just waiting to get a free day to go welding my new lower skinzseat replica
Some weights:
OFT roll over valve 540 gr
Oem bag with spare belt and couple of tools 1100 gr
My new litium battery 1500 gr
whitewheels
whitewheels
2" lower than skinz seat. Feels like I`ve should have made it even lower.....
Relocated litium battery and hotrod taillight
whitewheels
Done,but so much not worth it
The frame got 2" lower as I wanted but the seat got a bit high because the seatcover was sagging so I hade to add foam to the seat. Ended up with just little over 1" drop in seat hight. Alot of work for just 1" drop
The relocated litium battery turned out well ,but haven`t tested it in cold weather yet
whitewheels
Just to keep this thread together.....
Instead of a trailtank I got a 2 gallon rotopax in armygreen (awesome!). Best upgrade last season.
whitewheels
The k&n filter is going of next season. Why....my ridingstyle [emoji12]
....glad I had the ROV [emoji106]
whitewheels
After this I tought my season was over but 1 may it was springriding time.
Did some quick fixing to get it back on snow
whitewheels
The tree broke the lower (big) balljoint right of , front bumper smashed, steering rod bent, I got the nose cone staighten out with a heatgun and one of the two reflectors in the headlight smashed to bits......but I wasn't hurt so......no worries [emoji16]
Sportsterdanne
how did the battery work ? and what model is it ?
whitewheels
Work very well. Have been sitting in the sled for 3month. 13.28v!!! Thats freaking good for a battery that weight like a empty shell
It's a Euroglobe ELTX20HL 12v 380cca
Think it's originaly for a HD bike
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
nice build good luck with the repairs.
whitewheels
This weekend I started this seasons mods.
The steering is going to be a bit tidy and lighter. Moving to heater switches down. Titanium bars,crmo steering pole and studboy sharper bars
Biggest mod being the rad delete.
Thought I would lose som weight on the rad delete but it's gonna add weight instead [emoji20] So my goal to get under 250kg/550 lbs (wet) is not gonna happen.
whitewheels
