rocklong
Not here that I know of. I don't ride trails much at all though.
Ruggybuggy
- Sep 1, 2013
- Kenora, NWOnt, Canada
- 2007 Phazer FX 144
Jeffz said:It's required in Iowa and you must carry the card with.
Same here in Ontario and big fines for running without it.
rocklong
Maybe I better look into that. I guess I have to get it going before they can fine me. Haha
rocklong
The left side aluminum panel showed up today. My question is do I need a puller for the primary clutch or can u leave it on and still remove the side panel.
DaveRX1
When I had my 07 phazer, I took a jump and landed on a rock.. Broke a big chunk out of the frame by the spedo pick up. Mig welded it all back together, welded super e-z with a spool gun
rocklong
Thought about that but it was pretty bent and broken. Just replaced it the other day. Not bad except getting the bearing off secondary, it was really seized on. Got it all back on and I bolted a piece of angle iron under aluminum to protect it, should take a pretty good blow now.
yam177
- Aug 14, 2008
- Shoreview MN
- www.jbeurotech.com
It's not to bad to pull. Done it a few times
marpolsdofer
Having been a person who has disassembled a phazer bolt by bolt rivet by rivet and then built one back up again (engine was the only thing that stayed whole) it not that bad.
I have both of bulk heads and looking to get ride of them. PM me if you are interested.
To late it looks like.
rocklong
Yea I got the clutch side on and going to put the radiator side on today.
