Nytro'd40th
I'm sure this topic has been covered at least 64 times but I can't seem to find it in the search so here goes. The ski rubber for the C&A ski does the higher part of the rubber go to the front or back. I have it mounted to the back but for some reason I'm thinking thats not right. Thanks for your time
BLUEBALLER
- Jan 29, 2005
you are correct - it goes to the back - gets the ski tips level.
I still had to shim mine with a 1/4" shim just to get the skis tips up a bit.
2008 Nytro RTX
Didn't yours come with directions? When I got my skis did.
kingedwards99
I shimmed mine 1/2" with 2 pieces of a old track i cut, i tried with just one making it a 1/4" but it was still darty when you let off so i put two, its tight but it worked awsome, i also left my limiters straps at the stock setting and twisted the front shock of the skid aproximatley 1" up word taking some ski pressure off, this was a night and day diffrence in setup, i also have about 55lbs of psi in the front shocks. Good Luck
Yamadooed
- Dec 19, 2006
- Northern Illnoise
- 08 Nytro
05 Vector
09 TNT
02 MXZ
The taller part of the rubber faces forward on the C&A... Mine was the same as the stock ski rubber plus the 1/4" shim...
- 47K
