C&A's ?
boneman
Dalton, MA
Looking for feedback on c&a skis on Warrior, thinking about getting a set, any push in the corners? i'm not to worried about darting I want confidence in the corners first, how do they work with reverse? Looking at the ultra pro XT, price?
thanks in advance
Bone
I've got a set on mine and I like them. There is some push in the corners but its very predictable, and that is how I like them set up. Especially on a long track sled. I run them with no ski preasure at all, so I don't mind the push. If you try them you can add more ski preasure and they will not push at all. I also have the 12mm swy bar installed and found that it has almost eliminated the body roll.
Thanks for the info sledheadgeorge are yours the ultra pro xt's? I want something more agressive than the stockers i'm running with alot of ski preasure and no weight transfer they sound like what i'm looking for.
All of my riding buddies will agree on three things. The RX has the best headlights, has the warmest grips,and is the warmest sled. After that I have to earn their positive comments.
Stingray what do your buddy's ride? I bet there Revs, there cold mothers, how about that smooooooth genesis 4 stroke if they can't see that's a positive point then there opinion is not worth much. What does all this have to do with C&A skis?
I used the 6" c&a agressive trail ski. Not sure of the model number, but they do not have the grooves on the bottom. Those are the raCE VERSIONS. sAME EXACT SKI BUT NO GROOVES. iF YOU GET THE ONES WITH THE GROOVES ON THE BOTTOM YOU MIGHT NOT LIKE THE DARTING THAT YOU WILL MORE THAN LIKELY GET.
C&As had a good rep a few years ago.
You won't look back with a more aggressive ski. I put SLP PowderPros with 8" Bergstrom carbides on my Warrior, and the push is totally solved.
Turns really well now. I like the PowderPros because of the wings that give better flotation in deep snow cmpared to stock.
Darting is minimal, you just need to set the suspension and ski alignment properly.
