I have an 04 Warrior that just started running rough after a start. After running for a while it also started dripping fuel from the lower pan. I took off the air box and looked at the inlet of the carbs and noticed that one carb was particularly wet at the air intake. I fired up the sled again and looked into the front of that carb and noticed after running for about 30 seconds, fuel started flowing out of the little brass hole at the lower outside edge of the carb. There is also one of these brass holes on the other side as well. That one is not leaking. I believe this to be my idle problem. I have never cleaned these carbs and always stored the sled with Sea Foam in the summer. Do I need a cleaning or is this something else?
Yup pull the carbs time for a cleaning. Could be your float is stuck or just a lot of goo in there. But also check the float needle valve...should be rubber on that tip and no damage.
