tproteau
- Sep 28, 2014
- Wpg Manitoba
- 2003 Yamaha Rx-1 LE Liquid Silver
1998 Polaris XC 700
2007 Ski-Doo MXZ Adrenaline 800 HO
one carb is leaking fuel to the air box side the carbs have been apart and cleaned twice. The float seems to be moving free and the second time I had the carbs apart I switched the float valve and the seat with the ones from another carb and the carb still leaked fuel. The motor is being run without the air box on. Anyone have this happen before or understand what could be happening?
spr5088
- Jan 9, 2014
- Poughkeepsie NY
- 03 rx1
May sound like a silly question, but are the drain screws in correctly/deep enough?
tproteau
- Sep 28, 2014
- Wpg Manitoba
1998 Polaris XC 700
yes unfortunately, I wish it was that easyMay sound like a silly question, but are the drain screws in correctly/deep enough?
rxrenagade
- Jan 25, 2010
- Northern New Hampshire
- 2003 RX1 - Modified (Mine)
2004 SkiDoo Rev 600HO (Wife's Sled)
Sounds like a stuck float, try tapping on the carb bowl with the plastic end of a screwdriver. If that don't work, looks like you need to clean it again or possibly need a new float needle and seat.
tproteau
- Sep 28, 2014
- Wpg Manitoba
1998 Polaris XC 700
the floats are moving freely and the needle and seat from another carb were put into the one leaking fuel the symptoms stayed with the same carbSounds like a stuck float, try tapping on the carb bowl with the plastic end of a screwdriver. If that don't work, looks like you need to clean it again or possibly need a new float needle and seat.
tproteau
- Sep 28, 2014
- Wpg Manitoba
1998 Polaris XC 700
seems like the fuel is rushing out the main nozzle and that screw on the right front of the carb. only when the choke is off though.
tproteau
- Sep 28, 2014
- Wpg Manitoba
1998 Polaris XC 700
Is it possible for a float that moves freely on the work bench to get stuck while on the machine?
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
Replace the o-rings on the main jet nozzles. Might as well look your float bowl gaskets over too! Ethanol and time destroy them.
Fuel leaking around the drain screw story: A friend of mine gave my son a PW 80 dirt bike that had been sitting for God knows how long! I re-built the carb, it ran fine, but fuel leaked from the float bowl drain screw. I finally determined the end of the screw had been eaten away (rusted) from being exposed to water and crap in the float bowl. I ordered a new screw, put it in and the problem was gone. Hopefully that will fix your problem and the corrosion has not eaten into the float bowl seat too.
tproteau
- Sep 28, 2014
- Wpg Manitoba
1998 Polaris XC 700
I think it's actualy the o rings on the needle seat, main jet o rings still look to be in good shape.Replace the o-rings on the main jet nozzles. Might as well look your float bowl gaskets over too! Ethanol and time destroy them.
