Kens914
- Jan 19, 2013
- Apalachin, NY
- 2006 Attack
- United States
I have 2006 Attack that the cable adjuster from the shock came off. Can anyone tell me or take a picture of the routing of how to put it back in. It looks like it should go thru the wire frame thats attached to the arm? Parts fisch really dont show anything.
ranger1
Did the end just come un-screwed? My cable got ripped right out of the end that threads to the adjuster so instead of buying another cable that would more than likely get knocked off again, I removed the whole mechanism & covered the hole where it mounts to. If your cable is still good, just find a way to route it out of harms way.....unless someone can give you the factory routing of the cable
favarcat
ranger1 said:instead of buying another cable that would more than likely get knocked off again, I removed the whole mechanism & covered the hole where it mounts to.
Same exact thing I did after replacing it 3 or 4 times.
YammyRX1
Kens914
- Jan 19, 2013
- Apalachin, NY
- 2006 Attack
- United States
Cable adjuster
Thanks for the pic now I see why mine wont stay in. Missing the large plastic cover. Hope the new one works.
gas n go
Re: Cable adjuster
I grew so tired of trying to resolve this issue on our '06 that I finally adjusted it to what seems to be a reasonable ride then removed the cable too.
Kens914 said:Thanks for the pic now I see why mine wont stay in. Missing the large plastic cover. Hope the new one works.
