Could you post the manual instructions again? I can't view them for some reason
Yeah, that’s what I’m looking for.I made changes to the photos on the first page so they're nolonger linked to photobucket if that's what you're refering to.
My exhaust cam seems to be just a tad behind when the pointer is on the IIYeah, that’s what I’m looking for.
I’m doing my tensioner and was curious to read the Yamaha manual.
The marks on the both gears need to be aligned and the II mark on flywheel just close. The exhaust cam will want to rotate CW toward the intake cam because it's coming off the #3 exhaust lobe so it usually needs held in place while setting the chain. With the cams aligned if the chain is off by one tooth one the crank gear you won't see the II marks in the stator cover window.
#3 cylinder (stator side) lobes should be at 7 and 5.
"d" shows #3 cylinder cam lobe position when setting timing.
Hey Griz do I remember right the spacer tool was a 13mm deep 1/4 socket? Also how deep and wide are the cuts?
I am about to try this myself. If I lived near you I'd ask you to do it
Hey Grizz, Ive been trying not to bother you further with my adventure here but I have run in to a snag. Tool worked great by the way. when trying to install the new tensioner it stops abut 1/2 inch short of going all the way in. Now when I removed the old one it did snap back quite a bit but I didn't think much of that. I had the cables ties on the gears to timing wouldn't jump but when it released the tensioner I got slack in the chain which I know you take out with the exhaust cam ccw but should I try to do that and then try to install the tensioner? Have you ever had this happen?13mm, 1/4" drive deep well socket works. Notch it out leaving two tabs maybe 1/4" wide and 1/4" tall.
