TRUE BLUE SINCE 1980
- Apr 11, 2010
- Central PA
- '10 VECTOR LTX
A buddy of mine just called me (he is the free snowmobile mechanic in this area) He is working on a 06 Apex that sat for 2 seasons. It cranks over, the fuel pump is pumping and it will run if he sprays it.
Can the injectors get clogged and is there a way to open them up. Thanks in advance for any info.... He has it on the lift!
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Yes they can,
- Apr 11, 2010
- Central PA
- '10 VECTOR LTX
Any solutions ?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
You can pull them and clean them, have u checked the voltage on the battery
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Showing any codes?
- Apr 11, 2010
- Central PA
- '10 VECTOR LTX
No Codes, but the battery was dead , he has it on a charger.Showing any codes?
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Clean them then run a decent amount of Sea Foam through the tank, and continue to add some (100-200ml) for every tank after that.
I exclusively use Sea Foam and nothing else as it is also a fuel Stabilizer, and no carb related issues in years.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Spray some WD 40 on the injectors and let them sit. Had a Nytro do the same thing last fall. They freed up after a few hours.
- Apr 11, 2010
- Central PA
- '10 VECTOR LTX
Update;
Got the sled running .....ripped it across the yard today.
It must have been a combination of old gas,
dead battery and
THE HANDFULLS OF MOUSE BEDDING that flew out the exhaust tips.
dead battery and
Rich Kay
- Mar 29, 2006
- SE MI. Howell
- Yamaha apex rtx
A little tip for the mice problem guys seem to have.... When upon storing for the summer or even if the sled sits for a little time is to put steel wool pads into the exhaust tips or muffler can . not stuffed way in but just in the opening this will stop the issue. They will even try a piece which will later kill them off. I also did this on all my 2 strokes at the air box opening too... never a problem after.
