Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Has anyone done this ?
number1kyster
Limiter straps? Put a block of wood under the track directly under the center shock. That will give you the slack you need.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I did that , but there is very little room to get your hands and tools in at the bolts and nuts .Limiter straps? Put a block of wood under the track directly under the center shock. That will give you the slack you need.
Maybe I am not as nimble as I used to be .
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Do u want to shorten or lengthen the straps ?if you want to lengthen them you don’t need to put a block under the front part of the skid just lift the back of the sled up to make it easier and do one strap at a time.
0degC
- Jun 5, 2009
- Sudbury, Ontario
- 2023 SRX, 2017 XF 9000
It’s a bit hard to get at but allot easier than removing skid. If you have a way to lift back of sled off the ground and use a big block under front of track gives you a bit more room.I did that , but there is very little room to get your hands and tools in at the bolts and nuts .
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
shortenDo u want to shorten or lengthen the straps ?if you want to lengthen them you don’t need to put a block under the front part of the skid just lift the back of the sled up to make it easier and do one strap at a time.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Then do what 0degC said, or raise the rear up enough to get a jack underneath the centre shock and while sled is raised just jack it enough to shorten the straps. Fairly easy.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Without my son here to help me , I have become a semi useless tinkerer , unless there is unobstructed access to the job at hand ! (like track tightening )Then do what 0degC said, or raise the rear up enough to get a jack underneath the centre shock and while sled is raised just jack it enough to shorten the straps. Fairly easy.
Seeing as my only possibility of more riding this year , will be the Cochrane to Geraldton corridor , I will probably leave the straps till next year , as I may want the less ski pressure for those early morning spring riding crunchy trails .
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
Very easy to do with a 4x4 under the skid as mentioned above. We did mine in a parking lot in zero degree weather in about 8 minutes tops
