Can't get this thing softened up!
IMO- the nytro is too soft, I weigh 180lbs and I hit a 12" bump or bigger only travleling at 40mph and I bottom out. I set it stiff- doesn't help. Complained to dealer, took it apart, they thought it was soft and not much adjustment in the rear clicker shock. Someone told me to move the nuts all the way forward on the control rods to reduce weight shift to reduced inside ski lift in corners. Worked great, it carves corners, not much lift.
