Carb Sync W/SC
Maddog
NH
How inportant is a carb sync on a RX with a SC? Having tough time getting them even close. Center two are great. Outer two are way off. Is the method for sync the same? I have a motion pro tool.
Getting closer. Now three are dead on and one is way off. Not much seems to make much of a difference either. Where should I look?
I never experienced one way off, but did you check the little springs that are under the carb syn screws.
When I pulled my carbs apart to put in the billet T's, I got one of the springs twisted. Noticed it before the carbs were put back on the sled.
Also, could the pilot jet on that carb be clogged, or pitot screw for that carb be way off.
