dutchie84
I have 2003 rx1. I had the crabs off and cleaned them in and ultrasonic tank. This is the first time I have ever cleaned carbs so I'm a newbie. But I put everythIng back together and it ran good sitting on the trailer. But now that the snow is here I was going the try it out in the yard and i have problems. It's like the throttle is sticking, it will idle ok but then when I hit the gas it revs up and stays there, like 5,6,7000 rpm. I checked the cable and its not stuck. It slacks off when you release the throttle. Could the needles be sticking open?? Any help would be great.
mopar yam
- Nov 10, 2011
Check to see if your throttle position sensor is plugged in , did that on mine one time and it'll rev all over the place .
dutchie84
Its plugged in. I checked with a meter too and it seems to be in spec.
tedgoesfast
tors
bypass tors that should fix it
Not tors, tors will not let your rpms climb to the point where your clutch will kick in. Otherwise why have it if the sled can still move on its own. Clean your carbs again! Where is Indy he should of beat me to telling you to clean your carbs? lol
dutchie84
I took them off and cleaned them again, put them back in and tried it but the battery died before the bowls filled up with fuel. Probably for the best since it was late anyways. I'm going to try it again when I get home from work.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Make sure the carbs are fully inserted into the boots.
jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
- 2010 RS VECTOR GT LTX STOCK FOR NOW!
if you didnt pull jets and check them manually your piolts especially there plugged. I would check the piolt jets make sure you get a thin pice of wire and run it thru them! good luck just delt with this problem had to clean them 3 times this year!
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
The pilots are not in play at the RPM's he's having issuesjdp1under said:if you didnt pull jets and check them manually your piolts especially there plugged. I would check the piolt jets make sure you get a thin pice of wire and run it thru them! good luck just delt with this problem had to clean them 3 times this year!
apracing
- Feb 19, 2013
- new brunswick
- 2004 rx1 warrior 2006 apex gt 1979 enticer 340
what about the tops ,accel spring set in wrong place , or missing those small o rings or cracked rubber ...
apracing
- Feb 19, 2013
- new brunswick
i too would re clean the carbs ..plus with mine i tried the set the throttle up on rpms and it reved up high and dropped down ,
