Jaybaar
- Feb 22, 2021
- New Hampshire
- 16 SR Viper LTX DX
03 Yamaha RX1
For the first ride of the season I drove 2 hours north last night to go where there is marginal snow at best. Unloaded My 2016 LTX DX with 96 studs and hit the trails this morning and I kept getting stuck, which has never happened on this machine. Also noticed the read end was completely bottoming out very easily. Finally got off to take a look and only the rearmost 8" of the track was touching the ground. I assume the center shock is either A. Frozen or B. Toast. Am I correct in my assumption?
I'm heading North on Thursday for four days and need to chase down parts ASAP. Any help would be greatly appreciated, even the possibility of purchasing parts from a member. I'm in NH.
Thank you!
Thank you!
need shock. Looks like you got water in it and it froze or stuck.. needs rebuild or get a used one.
Jaybaar
- Feb 22, 2021
- New Hampshire
03 Yamaha RX1
Thank you Mr. Sled. It hasn't been outside at all this year, first time, so odd. I'll see if I can get a shock overnighted from somewhere - I'll do the rear at the same time.need shock. Looks like you got water in it and it froze or stuck.. needs rebuild or get a used one.
I had this happen on a first ride on the wife's sled. If you can have them both rebuilt would be the best but 2 new would do the trick. You must have some miles on the shock?Thank you Mr. Sled. It hasn't been outside at all this year, first time, so odd. I'll see if I can get a shock overnighted from somewhere - I'll do the rear at the same time.
Jaybaar
- Feb 22, 2021
- New Hampshire
03 Yamaha RX1
I would prefer that option as well, but time is against me. Yes, the sled has 6300 miles on it.I had this happen on a first ride on the wife's sled. If you can have them both rebuilt would be the best but 2 new would do the trick. You must have some miles on the shock?
Pretty common to have them stick with that many miles on. I rebuild usually 3 to 4000 miles .I would prefer that option as well, but time is against me. Yes, the sled has 6300 miles on it.
Jaybaar
- Feb 22, 2021
- New Hampshire
03 Yamaha RX1
Valuable information as always Mr. Sled, thank you!Pretty common to have them stick with that many miles on. I rebuild usually 3 to 4000 miles .
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
I have a center shock you may interested in
DennyTuna
- Jan 28, 2017
- Ohio
97 SX Vmax 600
Center shock QS3r out of my 18 sidewinder, fresh oil and nitrogen done by cannondale.
Nice!!Center shock QS3r out of my 18 sidewinder, fresh oil and nitrogen done by cannondale.
