Schradervalve style capWhat's the higher quality fix for this problem?
Thanks. I have these same shocks on my Cat ZR9000 Ltd.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
So what is the root cause of these shocks wearing?
Turboflash
- Mar 18, 2019
- Southern MN
Thank you. I take it someone has a direct-replacement cap (for QS3), or is this cap just a part from some other shock?
Direct replacement. Last year they were $35 with a refresh of $30 from me. Will know current pricing today when I call.Thank you. I take it someone has a direct-replacement cap (for QS3), or is this cap just a part from some other shock?
Which wear issue?So what is the root cause of these shocks wearing?
The wear on body is caused by the spring crossover sliding on it.
Mototown
- Sep 11, 2018
- Apex 40 th
Just checked my rear shocks with needle caps , that were rebuilt half way through last year , no measurable pressure drop of nitrogen . Centre shock oil had changed colour a little bit still not bad . Think it’s more to do with who’s rebuilding the shocks & regular 2000 mile maintenance.
Did you miss the part where I said this shock came right from factory like this? Your day will come.Just checked my rear shocks with needle caps , that were rebuilt half way through last year , no measurable pressure drop of nitrogen . Centre shock oil had changed colour a little bit still not bad . Think it’s more to do with who’s rebuilding the shocks & regular 2000 mile maintenance.
And here is another one. Front qs3. Untouched. Factory did this. Leaked nitrogen charge out through fill hole. That’s 2 in 2 weeks through here. If 3 position clicker doesn’t click and click firmly. Shock nitrogen charge has leaked out.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
steve the pic with blue dot is the stock needle valve,and is where you install the new shrader style valve?And here is another one. Front qs3. Untouched. Factory did this. Leaked nitrogen charge out through fill hole. That’s 2 in 2 weeks through here. If 3 position clicker doesn’t click and click firmly. Shock nitrogen charge has leaked out.
View attachment 149619 View attachment 149620
Yes Pete.steve the pic with blue dot is the stock needle valve,and is where you install the new shrader style valve?
- 7K
