The drive shaft and jack shaft bearings (on the chain case side), do they get greased or are they lubed by the oil, in chain case. And if so should i check and repack them?
Bearings on chaincase side are lubed by gear oil. Bearings on clutch side should be repacked with grease every season. We repack the bearings as part of std service on the Yamaha sleds.
