I was riding my 08 nytro fx last night and blew a belt it peeled of the top layer. While changing it I noticed the secondary turned about an 1/8 to 1/4 turn without moving the track. When you stop there is a clunk when I hit the gas again. The track ratchets when in powder but its seems tight as far as track sag. Is this normal or do I have some serious issues?
MOUNTY
With any reverse kit there is play without the track spinning. The track on these things need to be pretty tight with the stock drivers. Could possibly be a loose chaincase chain? Easy to check, loosten the jamb nut, finger tight the tensioner bolt then turn it out a quarter turn. Tighten jamb nut and try it again.
