markt111
- Feb 10, 2017
- Topsfield, Ma
- all Yamahas
It's time to do my top gear so I am going to replace the chain while it's apart, is the stock Yamaha chain the best option? Are there other options?
2017 LTX LE 22/41 gearing
also is there a better oil reservoir gasket?
Turboflash
- Mar 18, 2019
- Southern MN
Stock '18 & newer o-ring seal is just fine. As far as I know, the stock Yamaha/Cat chain is really the only option. They work fine, they just stretch over time. Best to use 15-wide gears and chain although 13 wide lower gear is fine too.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Stock chain is a Borg-Warner chain and very good quality. I believe Hurricane sells the same along with Wahl Bros.
Your dont need to replace the o-ring on the chain case cover, they are reusable no problem.
WindTime
- Feb 14, 2022
- bracebridge
- 2018 yamaha sidewinder
how many km should one expect to safely get from a stock chain runing a tune?
Fleecer
- Jun 13, 2014
- 2019 SRX
Might be a little tight to get new chain around 22/41 gears. Usually, I let it stretch a little with the 21/41 before gearing up to the 22.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Yes this is true.. A new chain can be installed on 22/41 gears but it very tight to start.. If you choose to install new chain on 22/41 gears be sure to take it easy for a 100 miles at least.. Letting it stretch a little with 21 top is a good idea though..Might be a little tight to get new chain around 22/41 gears. Usually, I let it stretch a little with the 21/41 before gearing up to the 22.
markt111
- Feb 10, 2017
- Topsfield, Ma
- all Yamahas
I ordered a stock one for replacement, seemed to have quite a bit of stretch at 8,000 miles!
Bigblue1
- Nov 29, 2007
- NY
- Sidewinder RTX-LE
Apex SE
When change the chain do you have change all the gears even if they look new?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Your gears are probably fine.. If they look good then the chain only is not a issue.. So NO you don't need to change the gears when doing a chain changeWhen change the chain do you have change all the gears even if they look new?
Bigblue1
- Nov 29, 2007
- NY
- Sidewinder RTX-LE
Apex SE
Thanks. Looks like I’ll be keeping it for a while so time for a full refresh. But for power steering and auto adjust suspension, looks and runs like new.Your gears are probably fine.. If they look good then the chain only is not a issue.. So NO you don't need to change the gears when doing a chain change
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
How many miles are we talking on chain Before changing. I know guys with original chains over 15,000 miles
