impalapower
I didn't see the plug for the chaincase so I could drain it. I can't get one of the bolts on the sidepanel off so I could only see part of the chaincase cover and tried to get my hands in there to feel where the plug is. Or do you have to pull the housing off and change it that way?
Tom-RX1
You have to get it from inside the tunnel
Tom=RX1
Tom=RX1
impalapower
I'll take a peek tomorrow, thanks. How much oil does it take?
Tom-RX1
I think about 8 ounces .
Tom-RX1
Tom-RX1
Focker
There is two different amounts for the chaincase, one is for the standard model and the other is for the reverse model. 8 ounces sounds about right but I cant remember for sure, it should say on your belt guard or in the manual. If you pull out your dipstick, one side is marked for the reverse and one is marked for the standard, at least that is how mine is with the reverse!
impalapower
I have the standard, could not afford reverse.
Superglide Sport
Changing Chaincase oil
I got sick and tired of taking the sled half apart to drain, clean and change the chaincase oil years ago. Now, I use a quick and easy method.
I picked up an oil suction pump and fitted an 18" length of 5/16" brake line to the hose. Now, I just insert the brake line into the bottom of the chain case after removing the dipstick, and suck out all the old oil. I usually do this after riding the sled while the lube is warm. I've also pre-heated the chaincase with a heatlamp to make it easier to remove all of the old oil.
Been using this method for years and it's quick and easy. Always adjust the chain tension at the same time you change the oil.
I've also been using Mobil 1 gear lube as well.
Regards,
Frank
Regards,
Frank
impalapower
Yes its best to do it when its hot.
LazyBastard
Re: Changing Chaincase oil
Question: Why wouldn't you just remove the drain bolt?
Superglide Sport said:I got sick and tired of taking the sled half apart to drain, clean and change the chaincase oil years ago. Now, I use a quick and easy method.
Regards,
Frank
Snowman269
- Dec 2, 2004
- Baraga, MI
- 06' Apex
14' KTM 500 EXC "SnowBike" fitted w/ 15' Timbersled LT
07' Phazer
My thoughts exactly.
ReX
I'm going to change my chaincase oil for the first time in a few days.
It looks like the oil will drain all over the track if you pull the plug. Am I missing something?
Tom-RX1
On mine it missed the track ran down into the tray wiped off with rag and filled up .Tom-RX1
LazyBastard
It won't touch the track. Just put a bucket under it.
