87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
I put on larger front wheels. As seen in the picture. I also tried Arctic Cat wheels in the middle..you can't see them here, but they are also 1/4" larger than stock and I machined 60 thous off the mounts, but never machined the front mounts even though they had the wider bearings now too.
I smoked off one of those middle wheels last week. Got 155 miles out of them. One was rubbing on the inside lug. I noticed this of the stock ones too, they coned towards each other. I think the mounts aren't centered. The one that blew last week was smoking hot! I think our wheels are blowing on the lakes..at least mine and a couple buddy's wheels are.
So the dealer finally got in the RX1 plastic wheels. So I took a pair of my stock UNCUT mounts from the front because the new wheels have the skinny bearings, and installed the plastic wheels in the middle. Then I stuck my big head under there and noticed that the damn wheels aren't centered very well. So then I installed them with the mounts that have 60 thous cut off them. Stuck my head in there again and the wheels appear to be more centered between the lugs.
So I haven't tried these wheels yet. I hope they last. I have heard that they get hot and warp, well I wonder if that is because they are centered between the lugs????
06RTXRider
Are you studded? any shock cleaance issues? Any idea of how the 05'wheels hold up with studs?
APEXER1
- Jan 3, 2006
- Catskills, New York
- purdyracing.com
It's funny you found that too. I had written a post about the idler wheels and had to take .090 off mine in the back to get them to line up with the maxxperf wheels. I did some checking with the doo wheels and found i had to take .075 off to get them to line up. One of the guys on here sent me his holders and i turned them down .075 for the doo wheels he's getting. We'll see how he makes out.
87gtNOS
- Nov 30, 2005
- Toronto
06RTXRider said:Are you studded? any shock cleaance issues? Any idea of how the 05'wheels hold up with studs?
Apparently just fine...we'll see!!
zipclean
Where is the best spot for low sno wheels,in front or towards the back.Attak >?? thanx
- 7K
