FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
2026 EXT858 Special
- YOUTUBE
- FrozenTows1
Can the shocks be removed without pulling the skid?
Or maybe I should ask, is it worth the effort trying to remove the shocks with the skid in place?
Mtnviper
- Aug 19, 2003
- Burlington Wa.
- fourstrokesolutionsllc.com
Not sure about the short tracks, but I know that you can pull the shocks with the skid in place on 141" and longer sleds. That said, it's probably a good idea to pull the skid during the off season so that you can check the tri-hub and other bearings.
Bill
Bill
X2 Great advice Mtnviper! Its so easy to pull the skid and install.
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
2026 EXT858 Special
- YOUTUBE
- FrozenTows1
Yeah, I had the skid out last season for the JT Stealth Kit install. Pretty straight forward.X2 Great advice Mtnviper! Its so easy to pull the skid and install.
Being a "bench guy", I'll just pull it and be done. Looking forward to a great season. Cheers.
Studroes144
- Oct 30, 2013
Being a "bench guy", I'll just pull it and be done. Looking forward to a great season. Cheers.![]()
Still on the xf7000? 137"? Both shocks can be pulled with the skid in place, honestly though I found I put in a lot more effort rolling around on my back and trying to get my fat fingers up in there while the skid was installed that I was able to pull the skid out and take shocks off in less time than what it took me to pull shocks with skid in, and definitely a lot less bangs on the knuckles with skid removed!
Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
X2
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
2026 EXT858 Special
- YOUTUBE
- FrozenTows1
Just completed the task of removing the shocks.
I can not imagine the agony of attempting to remove with the skid in place.
Shocks going to Fox tomorrow. Should feel like a new ride once the snow flies.
You revalving? Should send them to me.Just completed the task of removing the shocks.
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
2026 EXT858 Special
- YOUTUBE
- FrozenTows1
I had thought about that. My Son works at Fox here in Baxter. So I can drop them off before work today. The Foat 3's are getting the Evol kit. The skid shocks are just getting freshened up. Or what ever my Son thinks is best. He knows how we ride, so I'm giving him "chefs choice".You revalving? Should send them to me.
Honestly, I think that I'm the only one, nation wide, that is happy with the Float 3's & Cat IFP's factory settings. The only reason for the Evol upgrade is because I mentioned a vibration while pounding over the stutter bumps at 45-50 mph. Fox/Son said, "I think we can take care of that". Let it snow.
I would do same! I didn’t mind the float 3’s either but the Evols make them much better. Maybe have your son put a good aluminum ifp in the floats though.
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
The Evol's make a world of difference.
