tapp1
RX1MPete said:I use a 10mm wrench and if it fits between the bottom of the slider and the upper lip, it is time to change.
Thats a cool trick. I use a digital caliper from Harbor Freight. http://www.harborfreight.com/6-digital- ... 68304.html
yox185
If they are OEM then there will be a wear line on the side. When an section hits the line, replace.
rbell14
How about for DUPONT replacements? Same 10mm trick work? I don't recall if DUPONT has a wear line on them, I don't think so.
No line on the Duponts but I checked and 10mm will be right.Very thin at that point but not through.
bluesman
- Feb 28, 2011
- New Hampshire
- 09 Nytro XTX
How many miles do they normally last? What is the range?
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
depends on conditions u ride in... i get around 2,000 miles on usually. got 3200 on my last set.bluesman said:How many miles do they normally last? What is the range?
