I have a 05 Warrior with an expert X 136. I am purchasing Monkers MPI super charger kit. I need a new track anyway, so I was looking for some opinions. I run trails for the most part with some off trail. I also prefer to run studs. I was considering a Rip Saw 1.5 but have not yet decided. Also, are anti ratchet driver required since I have the Expert?
yamahajunkie
camo 9800 way better than the ripsaw.
monker
I would say stay 1.25 with studs. 1.5 if you don't. A camoplast 6-pitch pattern is probably the best bet. As much press as the ripsaw gets, I think the 6-pitch is much better especially off trail.
extros are always a plus as you can run your track looser.
yamahajunkie
monker do you have a yami skid? what drivers did you use with the charger? junkie
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
RipSaw or Predator are both great tracks. I agree with monker on max 1.25" lug height when studded, there are not too much room in there for a 1.5" studded track. I have run both RipSaw and Predator tracks and I find RipSaw the best for trail riding, but it is not a great off trail track. Predator is OK for trail riding and a good off trail track in my opinion, it also shines on water. With the stock skid install extroverts.
monker
yamahajunkie said:monker do you have a yami skid? what drivers did you use with the charger? junkie
I ran it with a m10. Stock drivers. I should have done extroverts at the time so I could run the track looser.
