Hey everyone, I'm having some issues with my charging system on my 09' Nytro with keeping the battery charged. The battery was replaced less than a year ago when I thought it was going bad, but it ended up being the voltage rectifier that needed to be replaced. Now, I've followed the service manual trouble shooting and come up with the following.
Voltage test on battery after charge is just over 12 volts
Voltage test on battery while running at 5,000 rpm is only 13.5 volts +/-
Ohm test on stator plug shows .1 - .2 (My multimeter only shows one decimal. Should be .22-.28)
Based on this and service manual specifications, I believe the stator may be bad. Any input to justify this or correct me is greatly appreciated. Also, If the stator is bad how the hell do I get to it to replace it. I've been searching for installation videos, manuals, etc and had no luck in finding any anything. Electrical fixes aren't my strong point, but I want to try and fix this myself and save my $ for hotel stays. Thanks again!
