MAMILLA
What are some easy things to do for my 09 mtx. Dont have money for turbo.
Idaho Nytro
First thing is to get rid of the maverick track
MAMILLA
Would it be a good idea to also put the super Q silencer on it I heard it sounds awesome and loses 8 lbs and gains 2-4 hp. Would it also be good to put simmons Gen II skis on or leave stock ones on.Idaho Nytro said:First thing is to get rid of the maverick track
Idaho Nytro
I put the gen 1s on mine and it made a big difference. Other than the track, skis, and power mad pivot riser that all i have done to mine.
MAMILLA
Did you have to extend any cables to get the riser to fit, and im guessing you went with the 2 inch.Idaho Nytro said:I put the gen 1s on mine and it made a big difference. Other than the track, skis, and power mad pivot riser that all i have done to mine.
Idaho Nytro
Did you have to extend any cables to get the riser to fit, and im guessing you went with the 2 inch.[/quote]
No, with the pivot adapter i used a 4" riser block. That way I stayed the same heighth as the stock riser, only moved the bars more foward. Ill get some pics in the morning.
MAMILLA
Idaho Nytro said:Did you have to extend any cables to get the riser to fit, and im guessing you went with the 2 inch.
No, with the pivot adapter i used a 4" riser block. That way I stayed the same heighth as the stock riser, only moved the bars more foward. Ill get some pics in the morning.[/quote]thanks man pics would be appreciated.
BBNytro
A cheap and easy ergonomic upgrade would be to put a steering relocation kit from wild child makes a hellofa difference. (wwildchild@hotmail.com)
Price: about $100
upgrade to a monsterworks.ca riser $379
Price: about $100
sonds
- Oct 7, 2008
- Golden Valley MN
- ductworksmn.com
- 08 T-Nytro
would not do a super q I had one, way to loud at wot. stock is like 83db ulta q is 95db. For shure dump the maverick track.
Idaho Nytro
I didnt get a chance to get any pics today. Sorry, I'll try tomorrow after work.
Hornet Handler
Betterboards!!!!!!!!!!!!!
lancelotlink
What skis do you recommend?
Idaho Nytro
simmons
outofbounds
Inexpensive mods
Install either Snow Eliminators or Better Boards. The stock boards don't evacuate snow very well. It doesn't cost much (under $150) to modify the stock boards and it makes a huge difference.
I have the SuperQ exhaust - it is rather loud. Good if you like that sort of thing, not so good if you like the quiet four-stroke experience.
MAMILLA
the gen II or gen IIdaho Nytro said:simmons
