br2an
- Sep 10, 2009
Well, that was a waste of time. Tried a couple of stores in Ontario and they are cash and carry only. Also, the SKU number listed on the US site (#1410305) is seven digits, SKU Canada uses a different numbering system (only 6 digits) so I wouldn't know if I were asking for the right part or not.
Any suggestions?
Any suggestions?
bdm
br2an,
If you can find a John Deere part supplier on line - I used part no. H33333 (replaced by A-481088) for mine. If you can find a catalog picture then you can make a judgment if that configuration can work for you. I think that I paid about $3 each.
br2an
- Sep 10, 2009
Spring Specifications online
Found a great site that shows the various type of springs available and their dimensions;
http://www.powellequipmentparts.com/bal ... _teeth.pdf
This store https://www.allpartsstore.com uses the same part numbers, website states they ship to US and Canada, but wouldn't process my online order. I got an email back saying they don't ship to Canada. Will try calling Monday to see what the problem is.
(and sorry for hijacking the thread)
Daranello
Suspended
Got them at my Yamaha dealer and love them, but they vibrate the sh$t out of my feet....tried to mount the rail ones but coulnt find a sutible location...
br2an
- Sep 10, 2009
Order is in! Phone in is ok, call the toll free at top of https://www.allpartsstore.com/. I ordered 6 pairs for $12.06 US plus another $20 shipping. Just use part numbers from http://www.powellequipmentparts.com/bal ... _teeth.pdf
By the way, I have 3 machines and will now have a set of ice scratchers for each. Works out to $10 each, including spare springs! The rest of the hardware I already have kicking around in the garage.
Will post a pic or two when I have them installed.
Thanks,
Brian
Thanks,
Brian
Highmiler
Scratchers
Which part # did you end up going with, as there are plenty to choose from?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
the uhmw seems to be the hardest to find
adrenaline junkey
sj said:the uhmw seems to be the hardest to find
You can use uhmw nylon delrin and my new favorite Nylon Molybdenum or nylatron.
Ebay has a lot of scrap stuff you can pick up pretty cheap too
Nylatron is a tradename for a family of nylon plastics, typically filled with molybdenum disulfide lubricant powder. It is used to cast plastic parts for machines, because of its mechanical properties and wear-resistance.
Nylatron is a brand name of DSM Plastics and was originally developed and manufactured by Polypenco.
Nylatron is used in rotary lever actuators where unusual shapes are required. They are also used as heavy-duty caster wheels, normally as a replacement for cast iron or forged steel
I just did my wife's phazer a few days ago and the ones i did in the first of this thread on my apex are holding up well but tips are getting worn down a little. probably replace them or put a little more bend on them this year
sk-rx1
I found a Yamaha upper A frame to spindle bolt worked out for me. Good quality and the right length.
grumpysanta
ok my question is what is TSC store in canada
Tractor Supply Company is not in CA that I know of. A farm tractor store if you have any will work.
grumpysanta
for the mount on a nitro rail , you mount on the first bolt crossover up front on the rail
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
grumpysanta said:ok my question is what is TSC store in canada
There is a store called TSC. there are quite a few in Ontario, at least around Ottawa.
I like this idea, would probably go for the longer bolt instead of drilling into my new skis.
ITHAPPENS
Closest one to Hudson is in Rockland, 40-50 kms from Hawksbury. http://www.tscstores.com/stage/mainhome.php
Zakre
FxsX24 said:can someone tell me WTH these do, i dont see the purpose
scratch the snow to cause spray to lubricate the sliders is the idea. Mostly in low snow conditions.
- 6K
