Clip position on Heavy spring??
SPEEDFREEK said:
who has spring!!1
Your dealer should have the spring in stock for the sogi shock,it was the ohlins spring that was on back order.
Heavy Spring Setup
I am 265 with my riding gear. I got my heavier rate spring for my Attak. I got clip in the second position. My spring adjuster on the third position. My spring sag is 44mm. Turned my compression adjuster back to middle position. Tried it last weekend and the rear end is just plain great. I want to get some time on the new spring and check the sag again after spring takes a set. Wish we had some winter...... :yam:
