monoshock C - clip position advice
I'm approx 215 without gear, and have my RX1 set on the second clip position and the #4 setting on the spring. Seems fine, However I ride aggressively but I am not in love with ditch banging or hitting mogels at warp speed.
Something that might help you guys out...
If you have a small bearing spreader and a pair of strut spring compressors it's easy to change the c-clip position on the sled.
Here is a picture from last season when I was moving my c-clip. It took about 15 minutes, but would probably take much less to do it again.
For my 05 I definitely prefer the stiffer spring. The stock spring just couldn't handle the bigger bumps.
