Was in the UP the other day and had my shock set on factory setting with tunnel dial set on soft I was going over some moguls at about 10 mph and noticed a major clunking sound I looked under the skid and noticed major slack in the limiter i assumed this is where the sound was coming from.. No adjustment like on the pro-action skid for the limiters..
I'm about 220 pounds in full gear so I guess I can't run the sled on the soft side.......drf
When you travel over moguls at slow speeds traction control rod will make a clunking noise as it shifts back and forth- nothing to worry about as far as I know.
Was riding in the U.P. this week and had the same clunking which I also had on last years Rage. My Attak clunks when going over larger or sharp bumps at slow speed, the suspension rises in the front as it hits the bumps and falls sharply as it travels over the bump and stops against the limiter strap causing the clunk. No probelm just the nature of the beast.
