clutch aligning
GreenMtnRx1
Vermont
I bought a ulmer clutch aligning tool. I had to move the engine forward almost a 1/8 inch and the secondary in 1/16 inch. Is this alot ? Will it make a big difference ? It has aways seemed this apex is just a touch slower than simular apexs did i find the reason ?
Check it after you run it, as in, drive it around for a bit.
Mine always wandered after adjusting....
Now did a custom jobby to keep the engine correct + a torque limiter
