clutch C/C
Rich Kay
SE MI. Howell
Yamaha apex rtx
Anyone have spec dimension 0n 2016 sr viper C/C for clutches? (not offset)
Thanks!
267-270mm
Thanks… working on my 16 viper I have found C/C to be out of spec to the short side. (262 mm) Knowing the range of just 3mm ( according to spec) is understandingly ok given the fact belts can vary a bit and belt defection "is" adjustable . I am for sure on the short side which has to effect things I would think. Getting a nice belt height adjustment should be easy to do with 262C/C but it has to effect full shift ratio...
Lots of great tech info here. Well worth the download.
https://drive.google.com/open?id=1-2AEZia93KSC-WtNnoUD7auqPlgeXHO-
Thanks! will down load. I will check again but the belts I have 8jp and 8dn showed almost perfectly the same length. I used the lead pencil marking one outside rib and rolled it on perfectly flat surface until mark appeared again and measured...
