putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
Absolutely love the Curves. Ran stock skis and Pilot 6.9's last year. Made the switch to curves and I can't believe the difference. Goes exactly where you point it and has a very nice and light steering. I do basically 99% trail riding and the curves handle amazing.
SISCAKIDD
CURVES...They are perfect on the viper
Alsim
- Oct 6, 2014
- LTX SE 2018
What kind of Curves XS leader package ? , carbides 6 inches ?, mount kit?, leading edge?
RTX21
- Oct 20, 2014
- Yamaha Viper RTX
What Curve model should I get?. I do mostly trail riding and once in a while I like to go off trail?
Studroes144
- Oct 30, 2013
Curve xs
SISCAKIDD
^^^^^ ditto^^^^^^^
RTX21
- Oct 20, 2014
- Yamaha Viper RTX
Ok. Next question. I currently run a 4 inch carbide with my limiter strap on the 2nd to last hole and I have studs. IM Pushing in the corners. Should i put 6 inchers on the curve xs or stay with the 4's?
larrypolaris
I ran the 4 in carbide until they wore out. They grabbed good when they were new.
But started to push when they got worn.
I have the 6 in now. The skis bite good in the corners now. But I only have 150 miles on them so far.
What I did notice was the 6 in were more darty then the 4 in. Not bad though.
csederlund
- Oct 7, 2012
- Frederic, WI
- 2014 LTX SE
I have the Curves with 6 inch round bars and 2" leading edge. The only time I get darting is at slow speed on a plowed road. I had the 4" leading edge on my Nytro and it never darted. It's worth the extra $80.
hoofer
- Feb 27, 2006
- WI
- 2015 Viper ltx-le
Which curve ski are you boys putting on the '14-15 Viper
hoofer
- Feb 27, 2006
- WI
- 2015 Viper ltx-le
never mind!... dug deeper and found the answer in previos post. XS
larrypolaris
Ahh, cool.
I have the 4" leading edge. I haven't installed them yet.
Wanted to run the ski's without them and compare.
I plan on putting them on before my next trip.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
I am having the same issue. After reading up some on here it appears that a lot of people are suggesting to back off the spring preload on the rear suspension's front shock.
What i will be trying is to back off all spring preload till the spring is loose/free. Then tighten the spring adjuster 2 turns
I would suggest you try this first since it is free.
