Carpet Guy
How often and what's everyone's method for cleaning the inner
PowderFalcon
Pinnin' it!
Air line. Blow them out after every trip
acetone on the shelves afterward
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Break cleaner. NON CHLORINATED. Every 900 miles or between trips.
Byam
Air after almost each ride! (300/500km) Belt removed ...
Red scotch brite first and the final touch whit acetone
Turboflash
- Mar 18, 2019
- Southern MN
IMO, it seems like acetone will actually clean better than most anything else. When I talked to Timken about a month ago, they recommended to use acetone, not brake cleaner.
P.S. Do not wash belts.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Does acetone come in a aerosol can?IMO, it seems like acetone will actually clean better than most anything else. When I talked to Timken about a month ago, they recommended to use acetone, not brake cleaner.
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Why not?IMO, it seems like acetone will actually clean better than most anything else. When I talked to Timken about a month ago, they recommended to use acetone, not brake cleaner.
JayM
- Oct 29, 2018
- Pickering, ON
- 2017 Sidewinder R-TX SE
Why not?
Old School to wash belts!
Turboflash
- Mar 18, 2019
- Southern MN
Don't think so. Pint steel can.Does acetone come in a aerosol can?
Turboflash
- Mar 18, 2019
- Southern MN
Back in the old days, belt manufacturers did use mold release agents when making belts so it was beneficial to put belts through dishwasher. Not any more. Modern manufacturing technologies don't need or use any release agents so we should not wash today's belts. BTW- nor should anyone clean belt w acetone or similar cleaners. Those chemicals do break down the rubber bonding agents in belt and are detrimental.Old School to wash belts!
Turboflash
- Mar 18, 2019
- Southern MN
Cleaning power and extremely fast evaporation w acetone. I think if you do a little test you'll see. Wipe your clutch with brake cleaner then wipe same clutch w acetone and clean rag. I think you'll see the acetone takes stuff off that brake cleaner doesn't?Why not?
SideHogger
- Apr 16, 2016
- upstate ny
No, I mean't, why not wash belts but if they claim no release agents anymore, maybe you don't have to. But I still wash with some Dawn detergent and let dry over my propane heater. Can't hurt, right?Cleaning power and extremely fast evaporation w acetone. I think if you do a little test you'll see. Wipe your clutch with brake cleaner then wipe same clutch w acetone and clean rag. I think you'll see the acetone takes stuff off that brake cleaner doesn't?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Let’s try not to beat turbo up to much here. He is making a point. I like brake cleaner because I can spray it into the rollers and all the tight spots. I’m guessing for the actual inside sheaves yes acetone is maybe slightly better. Green scotch pad and brake cleaner has been my go to. But I may just try acetone on INSIDE SHEAVES. Keep them clean no matter what you use is better then doing nothing to them. I NEVER treat my belts.
Turboflash
- Mar 18, 2019
- Southern MN
According to engineers at Timken, Dayco, and Gates, with today's belts, we should not wash them. The soap leaves residue on and IN the belt surface you cannot rinse off. Their point was is it just not necessary nor advisable. But, of course, everyone makes their own decision.No, I mean't, why not wash belts but if they claim no release agents anymore, maybe you don't have to. But I still wash with some Dawn detergent and let dry over my propane heater. Can't hurt, right?
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
If mine gets real dirty, I go in house when wife’s not there, spray the clutch down with simple green and then run it thru the dishwasher, it get everything off, make sure wife’s not home.
