Clutch kit installation help?
YamaMikeRTX
Newton MA/ N. Conway NH
I removed my clutches swaped parts. Now it's time to reinstall? Do I need to use a clutch alingment tool or can I just put them back on and go?? :dunno:
Just put them back on and go. As long as you put the shims in the same places, you'll be alright.
Don't forget you have a X inside the cover and another one inside the primary clutch,you must align them or you will have a vibration.The secondary is balance too,if you take the 2 sheave apart make sure too mark them before take apart.
their will be drill marks on each sheeve from balanceing line these up across from each other
