bigsur
I just installed a Ulmer Clutch kit in my Apex, and it greatly reduced the 4-stroke engine breaking effect. Do the Phazer kits do the same?
i installed a ulmer spring/weight kit on my phazer and also put a 136 track on....MUCH less engine braking...not sure if it is from the clutch kit or the track or both though...but i like it
rhino_live
ya it's from the clutch. I still ride a stock track...ulmer clutch kit does reduce engine breaking alot. again i think this is about the best $150 i ever spent on a snowmobile.
Heh Rhino what did you end up using for a helix setting with the ulmer clutch kit . I ended up using C-2. A1 my rpms were like 10800
Otter
Otter
yzf1999
- Dec 25, 2006
- Bloomington, Illinois
- 2015 Yamaha SR Viper LTX SE
It does reduce engine breaking alittle..
RJH
It seems the clutch kits…..that folks buy on this forum are well thought out.
What would decrease engine breaking – was interesting. The answer would be that the belt is staying high on the faces when you let off.
You would get the same feel….clutch reaction say…if you were going down a hill and let off. The secondary does not feel the load (as the track still turns a bit) and lets the belt stay high.
A bad way (but understandable) to describe it would be ….driving your 4 speed car in 3rd (at a good speed) and letting off the gas. As opposed to - letting off the gas (at a good speed) while driving in 1st.
If the sled can still pull this –then it’s a step in the right direction.
Weapon X
Isn't the engine braking a result of a good secondary clutch backshifting properly
RJH
Yes – backshifting alters the leverage by (as you are aware) moving the belt higher on the secondary and lower on the primary…..quickly. A 4/ is more pronounced than a 2/.
Yamaha uses an extra fuel gate to allow more fuel into the engine when you lift your thumb – this squirts a bit more raw fuel into the engine so it doesn’t rpm down as fast….and is designed to take away the engine braking.
In the case of the aftermarket clutches – they are set up more to what I would classify as drag race clutching. This style is for faster up shifting but it sacrifices a little backshift in the balance of things.
There is nothing wrong with that…customers are happy – sleds are faster than stock..and the big 4/ doesn’t seem to be bothered by a little more lugging to compensate – it has the power. It’s all good.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Actually the only sled that has the Engine Braking Reduction System (EBRS) is the FX Nytro models and I believe the new 120FI in the RS Venture GT for 2009. This actually pushes fresh cold air without any extra fuel into the intake tract under rapid deceleration of the throttle creating a lean condition causing the engine to hang up and this leads to a less effective engine braking.
