Phazer Ulmer Racing Clutch Kit
thedotz
I bought a used clutch for my 07 Phazer GT at a swap meet. I was told it had a Ulmer Racing Clutch kit installed. I took it apart and it has 89A10 Weights and a Solid Black spring. Can anyone with this kit confirm is. I really don't want to put this clutch on my sled if the weights and spring are way off. I hit a tree trunk with the side my sled over the weekend and damaged my clutch so needing to do something. I may just use my factory spring and weights if these don't pan out.
Thanks in advance
Brian
Thanks in advance
Brian
I would give Allen a call at Ulmer Racing....will check mine tonight !!
Thank you very much. I sent Ulmer Racing a email this morning. Really didn't want to put this on and be way off on weights and spring and mess something up on my sled.
