TrailxRider
I installed the Ulmer clutch kit and noticed my secondary clutch was very grimey and rough looking so I took the seconadry apart to clean. While reinstalling I realized I may not have installed the kit right the first time. During the instructions after the spring is set and the new helix is on the spring, it says to twist the helix clockwise until its lined with the holes to put the bolts back on. Does this require a lot of force to twist the helix? I tried briefly and it seams like it puts a lot of twist and pressure into the spring. Is this how it should be? I can line up the helix if I turn the sheave to the left just a little and it lines up but it doesnt put any twist into the spring. I want to make sure I'm doing this right and not break anything if I'm not supposed to put that much force and twist into the helix.
Instructions can be found here.
http://www.ulmerracing.com/ then click on instructions on left, then clutching. a PDF file will load and then scroll half way down to the Secondary section.
Hopeing to get an answere asap or atleast by tomorrow so I have time to get it all back together for the weekend.
Turk
Tech Advisor
You gotta turn clockwise & yes; it should be hard to do.
TrailxRider
Turk said:You gotta turn clockwise & yes; it should be hard to do.
Thanks Turk. If you dont turn it and install it would it cause backshifting issues and also belt problems? These are what I have been having and guessing it's because I never twisted it during the first install. Also at the very end once the bolts are on but not all the way on firm it says to turn so its not touching the button. Whats the button?
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
shud be painfully hard if you're doing it right
TrailxRider
woolyviper said:shud be painfully hard if you're doing it right
I'm doing it right now then haha one time I almost had it and then it spun around and I ended up with a small cut on my finger. Now I know its supposed to be that way so Ill try harder and get it on there and not worry about breaking something. Thanks for the quick replies
Grimm
There are 3 buttons on the secondary sheave that the helix slides on to open and close the secondary. When you are twisting the helix to line up the bolts, you have to be aware/careful not to allow the helix to break off a button or two.
It could happen...so I've heard, or done.
TrailxRider
Grimm said:There are 3 buttons on the secondary sheave that the helix slides on to open and close the secondary. When you are twisting the helix to line up the bolts, you have to be aware/careful not to allow the helix to break off a button or two.
are those the 3 black squares?
