muskrat
Installing a clutch kit and I am wondering if there are any tricks to it. Do I Lock tight anything? I have never done a Primary clutch before. Secondary is done. Thanks for the help, what would I do without this site.
Muskrat
Muskrat
bryantch
- Nov 21, 2004
primary is easier than the secondary imho but more time consuming. if you havent removed the side panel, you should as it will make your life easier. you do need locktight on all of the allen screws and i also put some on the through bolts. apparently the cover bolts dont need any locktight. also, make sure you line up the "x" on the inside of the cover with the "x" on the clutch. take your time and make sure not to lose the plastic washers.
other than that, pretty simple...just time consuming.
good luck
good luck
muskrat
Thanks Bryantch for the post, especially about plastic washers. Is the blue locktight ok?
Muskrat
Muskrat
thunder lips
- Apr 9, 2004
blue locktight will work for you.
