what do you guys think about this i rolled my sled last weekend and i screwed up my outer clutch sheave on my primer the and every tower has a chunk out of it. The bolts on the side pan pushed in to it . It runs preity trow but i it doesn't seam to vibrate should just replace that sheave can i. Because i just replace the hole thing last winter or can just grid out were the chunks came out in the same places evenly its only in the middle of the end of the towers not were the bolts go in for the cover
two important things to consider with clutches, structural integrety and balance. dont chince out on parts that can be replaced for a few hundred bucks. a clutch that grenades at high rpm can do damage that money cant fix.
