Clutch question
Blown Up
LaPorte, IN
Currently running my turbo viper helix at 6-1. I hit the rev limiter from hole shot. Being told to put back at 3-1. What will this do? Will I also lose top end rpm? If yes , approx how much?
do it. it'll be fine
it'll only take 5 min, try some things. It's the only way to learn ;)!
no need for a 3-1 wrap on a turbo sled I run that much on a n/a nitro...what spring color do you have in the secondary? try a 3-3
Yup answered this on the Viper side 3-3 will drop you 200 rpms
Heal weight....
87gtNOS said:
Heal weight....
loosening off that sec spring is not gonna help...it's gonna inhibit backshift as the looser spring is allowing it to upshift too much too early....
Control RPMs in the primary.
Softer initial primary spring or adjustable clutch weights.
A multiangle helix lie 49-41 would work keeping the RPMs Down off the line.
